IM C4500 powers off on it's own
  • Dark Helmet
    • May 2009
    • 865
    Howdy folks,
    Customers power went out then back on. Copier won't boot up now. It gets to the circle showing starting up then a screen with the red bar saying shutting down happens and it just shuts down. Had customer unplug machine and hit power switch 3 times. No dice.
    Anybody else seen this? We are thinking HDD or smart op firmware.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: IM C4500 powers off on it's own
    Originally posted by Lawrence
    Howdy folks,
    There's a bulletin about this also sc672
    Regards Mark
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Hope this helps good luck
      Regards Mark
      • Dark Helmet
        • May 2009
        • 865
        Just checked those TSB, Affected machines are 2020 of June and older. Mine is made Feb 2021. With the power event it does sound like that fuse could of died however. We are going out tomorrow morning to see.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Good luck
          Regards Mark
          • Dark Helmet
            • May 2009
            • 865
            Just a follow up:
            Even with the upgraded board in the machine, controller still resolved the issue.
            • Mark Bbb
              • Jun 2012
              • 1662
              Insurance matter. We call such machines 'totally unreliable' after a power breakdown.
              • DELCOM
                • Sep 2017
                • 2
                Got this problem today on a IM C6000
                After swapping the smart op with no result and was about to order a new controller board
                We found out it was only a bad ram stick.
                (I kept the 2gb rams from machine that need the upgrade to work with a fiery.)
                Hope this can help anyone !
