Firmware required for Lanier MP W7100 to support SMB2+?
  • PatD
    • Apr 2021
    • 13
    Can anyone tell me what firmware we'd need for a Lanier MP W7100 to support SMB2? I see in Ricoh's KBs that it does support it, but no idea what version. We're on 1.07 for the system/copy, 14.31 network support and 01.02 scanner.
  • rthonpm
    • Aug 2007
    • 2860
    Re: Firmware required for Lanier MP W7100 to support SMB2+?
    You need at minimum for SMB2/3 support:
    System 1.08
    Network Support 14.32
    Web Support 1.05
    Scanner 1.03
    Op Panel 1.03
    The current versions of all of these are:
    System 1.15
    Network Support 14.36
    Web Support 1.06
    Scanner 1.05
    Op Panel 1.04
    • PatD
      • Apr 2021
      • 13
      Thanks, that's all I needed!
        • 37644
        Does the MP W7100 happen to be one of the Wide Format models that requires the "File Format Converter" in order to scan to certain file types?
        • PatD
          • Apr 2021
          • 13
          Is it a wide-format, but no idea. It's under contract with the printer people, but I wanted to make sure we were clear on firmware versions, etc, before they give me the run around.
