Aficio MP C2500 - What causes this printing errors?
  • haemse
    • Jun 2021
    • 4
    Hi,
    I am having printing errors on my prints/copies. There are 3 dots and a slight stripe (barely visible) in regular intervals visilbe on every page A4 & A3
    See attached Scan of a test print.Ricoh Print Error - Scan 20210617113023983.pdf
    I've cleaned the PCU main roller several times, however they continue to persist.
    Where could they come from? How do I troupleshoot/fix it?
  • haemse
    • Jun 2021
    • 4
    Re: Aficio MP C2500 - What causes this printing errors?
    Oh, and i forgot do mention - the are soley in black color.
    • 8T2
      • Aug 2015
      • 257
      My first guess would be the black drum being chipped if I'm correct assuming the paper was fed SEF/Landscape
      *Edited a brain fart, SEF is not portrait
      Sent from my WAS-LX1 using Tapatalk
      • Gift
        • Mar 2011
        • 2413
        Originally posted by 8T2
        My first guess would be the black drum being chipped if I'm correct assuming the paper was fed SEF/Portrait
        yup just check the diameter of the drum and the distance between the repeating pattern - boom
        • Mark Bbb
          • Jun 2012
          • 1662
          black pcu, your technician was wright.
          • mikadonovan
            • May 2008
            • 2936
            Dots at 80mm, K drum damaged.
            NEVER ASSUME ANYTHING
            • haemse
              • Jun 2021
              • 4
              Thx you so much for your input, ill order a new one and keep you updated.
              • tonerhead
                • Sep 2009
                • 580
                Something like that should be easy to see on the black drum and verify.
                I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                Especially when it comes to sex
                • ridgemill
                  • Sep 2017
                  • 172
                  You can use either B224-2042 or D029-2256 on this model; the B224 is cheaper, but has a lower life.
                  • JayPaul
                    • Oct 2012
                    • 305
                    I loved the D029 2256 pcu, it had something like 50% extra life for about 20% extra cost. Slightly different modifications, cutting off corner of back and swapping 2 cables etc Those were the days
                    Now the new colour machines just slide in new parts and no rebuilding.
                    Anyway yeh that looks like black pcu all day long, you can essentially roll up that paper so 1 row of dots lines up with the other. The paper roll will be the same diameter of the drum.
                    • Zaxxon
                      • 608
                      You need to get out more
                      Please start you post with brand, model, problem.
                      • JayPaul
                        • Oct 2012
                        • 305
                        Then I won't even get into how much I love the new MP 301 PCDU... what a thing of beauty!
                        -Copiers are life
