Ethernet error + SC672-11 with new NVRAM on Ricoh MPC3003
  • General Copiers
    • Feb 2020
    • 27
    [Error Code] Ethernet error + SC672-11 with new NVRAM on Ricoh MPC3003
    Hello, we are Ricoh technicians with many years of experience and we are writing because we have a very unusual problem.
    One Ricoh MPC3003 of our customer suddenly stopped working as printer and scan to folder.
    Of course we first checked all network settings, using new ethernet cable etc. but the machine does not ping and the NIC lights don't come on.
    Having other MPC3003 available, we replaced all the boards, finally (and incredibly, in our experience) finding the problem in the NVRAM Total Counter Service Set.
    To solve the problem for the customer, we then put our NVRAMs in his machine and, by changing the serial number, everything worked perfectly.
    Obviously the identical network problem appears with his NVRAMs on our machine so we ordered new NVRAM Total Counter Service Sets (but, given the cost, not directly from Ricoh).
    Installing these new NVRAMs, the machine doesn't go on "ready" and we have the error code SC672-11, which has nothing to do with what is written in the service manual (communication between the controller and the operating panel, control board or USB cable), because our MPC3003 works perfectly with other NVRAMs.
    With this SC code, we can't to do a firmware update or a nvram data download from a sd card (SP5-825-001).
    We think these NVRAM Total Counter Service Set are formatted, haven't communication with control board and we have to initialise them with pre-existing files.
    We obviously want to clarify that we had no intention of resetting the total counter, but only replacement them because of the network problem.
    Can you give some advice?
    Sorry for the length of the text...
    Thank you very much.
