ricoh 2232c optional fax problem
  • leontism
    • 7
    hello i am new here.i hope someone help me.
    i have a problem with the fax card of my copy machine.
    it is used from usa.it works but i can't send or recieve fax.
    is it possible to need any further settings
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 365
    If it won't send or receive, it's NOT working.
    Country Code is set on Fax SC/System Switch/OF......
    Probably more settings. Dig out your manual and search for Country Code, this will lead you to the settings for your region.
    The reason is that phone protocols differ from country to country.
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • leontism
      • 7
      thank you!
      can i change the codes manualy?
      the service manual don't help.
      do you have any solutions or manual for this fax kit?
      • KopyKat
        • Nov 2008
        • 365
        In your SM toward the end you should have the manuals for the options. Fax Option B603 located just after the Booklet Finisher section.
        sigpic
        • leontism
          • 7
          i have this sm
          Model J-C1y/z
          (Machine Code: B146/B147/B148/B149)
          do you know where can i find b 603 manual?
          thank you in advance!
          • KopyKat
            • Nov 2008
            • 365
            It is in the main manual for the MFP as stated above. At least in mine it is.
            sigpic
            • category_five
              • 93
              2232c manuals were removed from ricoh.com. Seems a bit early in the product's life to pull them. You can probably call customer service to purchase them.
              Information is intended for certified service personnel only. Your mileage may vary, see dealer for details.
              • KopyKat
                • Nov 2008
                • 365
                The SM's are still up on the tsc web site. Registered tech access only.
                sigpic
                • leontism
                  • 7
                  thank you
