SC 436 - Ricoh C901
  • anp
    • Jun 2021
    • 5
    [Error Code] SC 436 - Ricoh C901
    Dear,
    My name is Van. I have problem SC436 with Ricoh C901. I try below:
    - Clean and Change potential sensor ==> Still not working ==> SC436
    - Change other Development (of machine working) ==> Still not working ==>SC436
    - I executed on 3820 , then check code on 3821 check log "16999999"
    Please give me advise
    Thanks all
    • 37739
    Re: SC 436 - Ricoh C901
    The 16999999 indicates a 16 failure code on K after which the process terminated because of the K error. For troubleshooting the 16 failure, see the Process Control Troubleshooting section of the service manual. If you do not have a manual, you should not be working on production color machines.
    • anp
      • Jun 2021
      • 5
      Dear,
      I've change Developer K (Drum, Charge and Potential sensor) but still have problem 436. I've read Service manual at "VdHome Error 2" (Display code: 16) but i can not fix it.
      • anp
        • Jun 2021
        • 5
        UP!
        • moskalyof
          • Jul 2018
          • 2
          Originally posted by anp
          UP!
          Hello! Did you ever resolve this issue? We have the same error, but SC 436 - 15. Already swapped one sensor, changed the drum, but it's still doesnt go away.
          • anp
            • Jun 2021
            • 5
            Hi, Clean this sensor.
