SC 362-03 ON a RICOH MPC4503
  • fshead
    • 2376
    I have a mpc4503 that customer wants me to ck out.
    Will not clear sc362 code magenta developer code.
    As I recall this machine was running light in density on magenta color.
    Meter is close to 400k so i am going to inspect unit later today.
    Not sure if changing the developer powder would be an option.
    2ND does the magenta dev unitD186-3073 come with developer powder?
    thanks
  • COPIERMAN
    • Jun 2009
    • 559
    Re: SC 362-03 ON a RICOH MPC4503
    yes it should have devlp powder in it. You might also want to change drum too.
    Developer Yield, Color: C/M/Y: Estimated 600,000 Pages
    Drum Yield, Color: C/M/Y: Estimated 270,000 Pages
    • fshead
      • 2376
      thanks
      customer is cheap as hell and i just need to get him running.
      he has been using a damaged fuser belt for the last 16 months which gives a reprint mark
      on copies..When it breaks completly is when he will change it..
      • davel
        • Oct 2011
        • 1107
        It is broken completely now.
        • sandmanmac
          • 3983
          Not sure where you got these specs, but mine from the product support guide show that both the colour dev units and Drums are rated for 270K, while The K-dev unit is rated for 600k and drum for 400K
          PM Schedule.pdf
          • mikadonovan
            • May 2008
            • 2931
            No separate Ricoh developer with these units, you have to buy the whole dev unit. Something to consider, it could also be the toner pump has failed.
            ALTHOUGH, I just did a search and these people offer an aftermarket bag of developer. I have no idea if it's any good or not.
            d1773022 RICOH DEVELOPER Fits mp-c4503 Lowest Prices Guaranteed. Ships Today.
            NEVER ASSUME ANYTHING
            • sandmanmac
              • 3983
              d1773022 RICOHDEVELOPER Fits mp-c4503
              I have a source for the dev that I buy a lot of parts and supplies for Ricoh, and have a really good luck.
              A lot of their products, while listed as generic, I'm convinced are Original Products, and some even come with the familiar Ricoh product code labeling.
              Ricoh Magenta Developper OEM
              My Cdn $ cost is about $70, so that's probably about $10 U.S.
              I bought a bag of C3503 Dev from them a while ago to give it a try, but couldn't figure out how to get the damn unit apart to empty/ refill it
              All I managed to do was break a bunch of plastic clips, and make it unusable, so if anyone that may have done it in the past has any advice or instructions to share, I'd really appreciate it.
                • 37553
                I think that is why Ricoh does not sell just the developer.
