Ricoh MP 3054 card reader disable
  • patterson70
    • May 2010
    • 599
    Hello , I ran into an MP 3054 with a card reader that is requiring a log in. I unplugged it and need to disable the log in message. Where in service mode could I do this if at all? Or in WIM do I override it there?
    • 37488
    More likely to be either a control panel or WIM setting. Most card readers have an app associated with and that app is set as the Default Function. Default function needs to be set back to the Home screen or what ever function you use most and the app need to be uninstalled.
    • sandmanmac
      • 3981
      As Tim said, there's probably an App that needs removing in the Screen SP Mode, and possibly something in User tools / machine settings/ extended features that needs removing.
      • Polo-022
        • Sep 2007
        • 486
        Service Manual -Page 714 - SP 5-113-___
        • patterson70
          • May 2010
          • 599
          Much appreciated. I will get by the machine soon and try these suggestions and let you know the outcome.
