Can't reset fuser after SC544 in service mode on Aficio 4502
  • Doug James
    • Jan 2012
    • 935
    Very Strange... I pu a new fuser in this machine and when I go to service mode 5801 shows memory clear. I checked all the modes 801 and none say clear fuser error. Any help will be very appreciated THANKS !!!
    • 37048
    Try SP 5810. You're not the first one to transpose the last two digits.
    • sandmanmac
      • 3973
      Tim's right, and it's 5810-002, and you'll also need to install a PICO fuse on that fuser first in order to reset it - unless it's a brand new fuser (which I doubt).
      • Doug James
        • Jan 2012
        • 935
        Thanks so much !!!! And I appreciate the lifeline.... Believe or not I have been doing this for 30 years and reset hundreds.... Ugh I feel pretty stupid...
          • 37048
          :Like I said, you were not the first one and most likely won't be the last.
          • DH1980
            • Mar 2009
            • 52
            Had a C4502 that would not reset and had to replace thermostats and all fuses - everything in the fuser and it started working. Not sure what the trouble was but it went away.
            • Dark Helmet
              • May 2009
              • 835
              I ripped a door switch out of a MP 201 extra tray and ripped a long length of thin wire from something else, took a old fuse, cut the fuse off the connector, soldered everything up.
              You can plug said fuse connector / wire switch contraption into the fuser your trying to rescue, carefully close the door after doing 5810 / reboot. With a MP 201 switch, if i recall the switch was closed the button was not pressed so you waited 2 seconds after closing the door and then held the button down. The machine would return to life and if that fuser was actually ok the machine works afterwards.
              I was on a training course for MP C3004 and told the instructor i made one of those up. He plugged his ears and closed his eyes and went na na na na
                • 37048
                There was a discussion on that here on CTN a few years ago.
