RICOH MPC8003 magenta background
  • enricos
    • Mar 2019
    • 19
    Hi everyone,
    I have a costumer with a MPC8003, the copier has 1.038.000 b/w prints and 93.000 color prints. Last week the costumer called for magenta background behind color prints. I've done all SP 3011 (Manual ProCon, Density Adjustment and so on) and ACC, the quality has improved a lot but after a week the problem it's still there. Any suggestions?
  • COPIERMAN
    • Jun 2009
    • 559
    Re: RICOH MPC8003 magenta background
    does it do this on copy too. i would replace magenta pcu assy.you didn't say when that unit was replace and how many copies are on it.
    • davel
      • Oct 2011
      • 1107
      Start by cleaning the M pcu.
      • enricos
        • Mar 2019
        • 19
        It does it in copy mode too.
        I disassembled PCDU M and vacumed the unit, there was nothing strange in it.
        Color PCDUs have never been touched since cleaning unit and other parts have to be changed at 300k color prints
        • Oceman2
          Reluctant Copier Dude
          • Jul 2021
          • 1
          Try replacing the potential sensor, or swapping it with another color. Those are very flaky and can cause all sorts of backgrounding. Part # is D0143655. Cleaning with a brush may help as well, but the sensors are very sensitive.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            You can get a build up of toner on the dev assy make sure you clean all sensors these machines need a lot of servicing.
            Regards Mark
            • enricos
              • Mar 2019
              • 19
              Hi, I've swapped the potential sensor with the yellow one, after more than a month the problem seems to be resolved
