no multicopy
  • romnick
    • Aug 2008
    • 56
    no multicopy
    i have Ricoh 1015 it does not give multicopy
    i check already copy features max. copy quantity,
    it is set to 99. what may be the reason.please help
    thany you in advance.
  • 10871087
    • Jan 2005
    • 1062
    Is the "Add Toner" light on? many copier models will only make one at a time if it is low on toner
    • Eric1968
      • 2458
      I think the (optional) 16MB memory is not present. When you want to make multiple copies, you need this memory.
      • Ricoh-ono
        • 340
        I would have this happen on some machines if I was copying from the platen glass and the default setting was for stack/sort.
        Do what you can, with what you have, where you are. ~Theodore Roosevelt
