Aficio MP161 -Print /Scan card
  • sandmanmac
    • 3979
    Does anyone have any idea where I might pick up a Print /Scan SD card for an MP161 SPF (reasonably). I picked up a really low count unit, but the card is missing -it might not have been as good a deal as I thought??
    And another question....Is that also why the fax doesn't respond? Or am I missing something else too? I'm not to familiar with these boxes, and the service manual wasn't a great deal of help either.
  • RicohPRO
    5638 Hater
    • May 2009
    • 14
    what are you looking to spend on the print/scan card? and when you say the fax doesn't respond... can you clarify that just a little more? it doesn't pick up when someone calls it? it doesn't connect to another fax machine when sending a fax out? what's the machine doing (or not doing)?
    • sandmanmac
      • 3979
      I should have said that the 'fax feature' is not available. At this point, I've come to the conclusion that the Print /Scan card is what also enables the fax feature, because the fax card would be removed to install the other SD card. Is that right?
      As far as what I want to spend on the card, I'm not exactly sure, but if you have a suggestion for me, I'd be interested in hearing it.
      I agreed to purchase this machine for resale from a small wholesaler here, but after it was delivered, I realized that the extra features didn't work, so I am simply holding onto it now until they either get me another machine, or the card to make this one work.
      • countrytech
        • Mar 2009
        • 68
        Hi
        Does the machine have a fax control unit fitted? If there is, you would more than likely need a fax address SD card. However when installing the scan/print card the fax SD is to be removed. Hope this is a help.
        • sandmanmac
          • 3979
          Yes. All the features are installed. I am simply missing the SD card.
          • Eric1968
            • 2458
            There are 2 SD-cards :
            Printer SD : B892 5049
            Fax SD : B868 5099
            Hope this information helps.
