Ricoh MP C4502 doc feeder
  • thurmmy
    • Aug 2016
    • 102
    Could someone help me out with a part number for the reverse roller drive shaft, not the one with the roller on it but the one that drives it with the 2 press fit gears on it. It is the DF 3060 D578. Thank you in advance.
    • 37553
    Re: Ricoh MP C4502 doc feeder
    How about some clarification? The DF 3060 does not come on the MP C4502/5502. Now do you have a MP C4502 with either an ARDF DF 3070 or SPDF. Or do you have a MP C3502/3002 which does use the DF 3060.
    • thurmmy
      • Aug 2016
      • 102
      Slimslob, hmmm. The product support says that is what it is. I didn't think to get the data plate info off the Doc Feeder before I left the account. I will double check before I order thou.
      • thurmmy
        • Aug 2016
        • 102
        After looking at the 3060 parts catalog, Slimslob you are correct. That is not the Doc Feeder that is on it. Thank you! I will go back and get the model number tomorrow and then proceed from there. Thanks again.
          • 37553
          The information I posted came from Product Support Guides and Service Manuals. The MP C4502 normally shipped with the SPDF. If you wanted the ARDF you had to special order.
            • 37553
            If there are 12 cables going from the Doc Feeder to the main frame, it is a SPDF. One is the standard DF connection and the other is for the CIS, contact image scanner.
            • sandmanmac
              • 3983
              It's a DF3070 and the same as the ARDF on the MP4002/5002, so this is what I expect you're looking for (#20)
              I've replaced a bunch.
              P/N: B802 2231
              ARDF.pdf
              Edit: I pasted the wrong P/N initially.
