imc 8000
  • T911
    • Jun 2007
    • 628
    imc 8000
    what is the reset procedure when replacing the cyan cleaning unit? Machine is asking for it.
    Thx
  • davel
    • Oct 2011
    • 1089
    It is in the manual.
    • T911
      • Jun 2007
      • 628
      I turned 3701 to 1 for the unit, reset the pm list. still shows up. do i need to go into 7622 as well? Thanks
      • Leoculus
        • Jul 2024
        • 62
        did you replace the cleaning unit? there are 2 switches on the cleaning unit that are triggered when the lube bar wears down. uneven wear on the lube bar will often trigger one of them. i had a c6503 that had the same problem after rebuilding the cleaning unit. one of the switches was stuck in the actuated position.
