MP C3502 scan to folder using Kerberos authenication
    • 37316
    #16
    Re: MP C3502 scan to folder using Kerberos authenication
    Originally posted by it_guy
    Thank you for the document. It confirms that the realm name MUST be in capital letters, page 722, which it is.
    I think we are getting the issue confused. I want to enable Kerberos authentication ONLY for scanning to folders. I don't need or want the users to login to the copier. I just need to authenticate to the server to save the file to correct destination via the Address Book. I tried enabling logging: Device Management, Configuration, Logs, and set Collect Job Logs to active with only the Scanning: options set to Collect. Everything else was set to Do not Collect. The logs don't tell me anything useful about WHY Kerberos is not being used. The access logs don't look like anything useful for this problem.
    When setting up Authentication you can specify which function require it. Specify scanning only.
