Ricoh PB3220 right door stuck - solution found
  • mlandry71
    • Sep 2014
    • 24
    If anyone has a stuck door on a PB3220, I have a solution to prevent the door hooks from over rotating and getting stuck under the pins on the feeder frame again.
    I found that you can carefully split an ADF sep roller (A859-2241) in half and it will fit perfectly snug inside the cover above the release handle.
    I would add more images but I can't for some reason. Anyway, squeeze the half of the roller inside the door guide right next to the round post that sticks up straddling the plastic ridge. This acts as a stopper for the latch handle keeping it from over rotating and sticking.
    I also made a google photos album, but I'm not sure if this link be to be allowed to work...
    Ricoh PB3220 door fix - Google Photos
    -MIke, copier tech in FL,USA
  • guitar9199
    • Sep 2016
    • 1100
    Re: Ricoh PB3220 right door stuck - solution found
    [ATTACH=CONFIG]50015[/ATTACH]
    [ATTACH=CONFIG]50016[/ATTACH]
    [ATTACH=CONFIG]50017[/ATTACH]
    I would add more images but I can't for some reason. Anyway, squeeze the half of the roller inside the door guide right next to the round post that sticks up. This acts as a stopper for the latch handle keeping it from over rotating and sticking.
    That's some pretty good "MacGuyvering" right there....
    (Is that even a word??....)
