MP 4002 and SR3110 does not staple, only printing
  • UNICORNico
    • May 2018
    • 308
    Good dear colleagues.
    Today I have a curious topic with an MP 4002 and SR3110.
    Stapling and punching in "copy mode" works without problem, but when it is printing, the device DOES NOT STAPLE.
    Both machine and classifier, are updated and are using the most current drivers.
    Can there be an internal configuration parameter that disables stapling when printing?
    Best regards.
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
  • mikadonovan
    • May 2008
    • 2931
    Re: MP 4002 and SR3110 does not staple, only printing
    Go to devices and printers on the computer, right click the printer and select printer properties. Look under the accessories tab and make sure correct finisher has been added.
    NEVER ASSUME ANYTHING
      • 37495
      And if the driver is shared out by a print server it will only be available if added on the server. Had that problem with a hospital once.
      • Mark Bbb
        • Jun 2012
        • 1662
        or the print driver is not pcl6 Ricoh mp4002
        • UNICORNico
          • May 2018
          • 308
          I am sorry to notify that it has not served me.
          The driver is PCL6, and in features the SR3110 is marked. Stapling is default, and still does not staple.
          So check to see if it could be something from Service Mode that is bypassing stapling when printing.
          • Mark Bbb
            • Jun 2012
            • 1662
            Erase driver and port, and reinstall the printer
            • UNICORNico
              • May 2018
              • 308
              Thank you for your suggestions. I will try them. (Although the PCL6 are installed recently, since before there were the "Microsoft Universals")
              With regard to the "server" thing, there is no server that manages the printing issue, since the print drivers are installed locally on all PCs.
              • Mark Bbb
                • Jun 2012
                • 1662
                Connect your lap top, same problem?
                • UNICORNico
                  • May 2018
                  • 308
                  Thanks for the suggestion. But the same thing happens on any other PC or Laptop.
                  Seriously I think that it must be something of internal configuration that does not allow to execute the stapling, from the printing.
                  I apologize for the delay in answering, since this client is not a priority, and I must attend other services. Nevertheless, I appreciate any suggestions.
                    • 37495
                    Is there any message displayed when they try to staple? They may be trying to staple from a tray that stapling is turned off or trying to center staple to paper that is not short edge feed.
                    • UNICORNico
                      • May 2018
                      • 308
                      The stapling is enabled in all drawers. Otherwise, photocopying would NOT staple, but YES staple.
                      In all drawers it is indicated as normal paper of 80gr. with option of stapled and double-sided active.
                      The machine as soon as it receives the printing order (although this is the selected option to staple) it performs the work with total normality without indicating ANYTHING per screen, and WITHOUT STAPLING.
                      Obviously something happens here that is foreign to the driver and must be something internal to the device.
                        • 37495
                        If they can staple when copying, then the only thing internal to the machine would be firmware. Printer, PCL Language or Network
                        • UNICORNico
                          • May 2018
                          • 308
                          Thank you.
                          For something so obvious, and I didn't realize it.
                          Definitely another thing to add to the long list of "weird things that happen if you don't update the firmware" xD lol
