Ricoh Pro C751ex jammimg at D2/D3
  • Zesti
    • Jun 2009
    • 308
    [Jamming] Ricoh Pro C751ex jammimg at D2/D3
    Hi there,
    I'm basically a KonicaMinolta tech. Happen to see this C751ex with a jammimg indication at D2/D3. The sensor status in 5803-8 bit 4 is constantly 0, means there is a paper there. I have cheked by swapping the sensor with a working one, the status is 0. Once we pull out left side unit the status changes to 1.
    There are no local Ricoh techs experience with Ricoh digital presses.
    Any lead about the fault?
  • Zesti
    • Jun 2009
    • 308
    Re: Ricoh Pro C751ex jammimg at D2/D3
    Got it solved..... quite confusion in going through available service manual. Simply disconnected the following sensor, mentioned by 2 different names in SM:
    Pressure Roller Paper Sensor
