MPC3004 mac driver
  • GeorgeBest
    • Jul 2009
    • 525
    MPC3004 mac driver
    Hi,
    Mc's can print standard on this device with Adobe PDf emulation, no PS3
    Got some problems with printing to the MPC with Mc, for example , installed the right driver (Catalina), when sending a job, the printer makes noise, as if it receives data but no prints coming out.
    Is a PS3 option needed for an MPC3004 printing from different versions?
    thanks in advance
  • Codex
    • May 2008
    • 701
    Re: MPC3004 mac driver
    Originally posted by GeorgeBest
    Hi,
    thanks in advance
    Hello
    Try the "hp jetdirect" printer, it should work
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
    • GeorgeBest
      • Jul 2009
      • 525
      I always choose for the HP jetdirect printing, normally it al works . . .
      Originally posted by Codex
      Hello
      • COPIERMAN
        • Jun 2009
        • 559
        if they are using user codes to track copy and prints will also cause this . you need to enable that under job log and enable user code and enter a code that has been setup for that person.
          • 37458
          And I believe that in order to enter user codes in the driver will require the proper Ricoh PPD installer being ran to install an actual Ricoh driver.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Hi,
            thanks in advance
            If ps3 option not fitted use air print not as good missing fonts etc
            Regards Mark
            • rthonpm
              • Aug 2007
              • 2853
              All Apple devices use CUPS as their print engine, which uses PostScript as its native interpreter. For the best possible support you will need the option, otherwise you're just trying to bandage the system which makes the customer unhappy and your life that much more difficult.
              Sent from my BlackBerry using Tapatalk
                • 37458
                Ricoh's PDF direct operationally is a subset of PS3 and supports most everyday printing needs. However is does not support any of the advanced features used for desktop publishing that are licensed from Adobe. For 100% compatibility the PS3 SD card is needed. What you are paying for on the PS3 is the licensing.
