Ricoh C7100 uneven color
  • Chrb
    • Oct 2024
    • 11
    Hello again,
    I'm having problem with the C7100 machine .
    it gives uneven density only for the color but the black color is very good.
    I changed the ITB same problem and the drum also same , any suggestions please , attached is the print sample
    • 37487
    If you have changed the ITB unit with a good one, then you might have a problem with the mechanism that lifts the color transfer rollers inside the ITB.
    • bat
      • Sep 2008
      • 140
      Looks like a Developer Unit problem...
      • MIGUELMARCHENA
        • Feb 2018
        • 194
        It seems that the revledaor is scarce in the color units but it could also be in the band that the mechanism within the band is not activated as the slimlob master teaches and bat
        • Chrb
          • Oct 2024
          • 11
          Update.
          Thank you all for your help.
          After changing the ITB and check that all the lifting motors working fine, I change the 3 developers with new drum and charge , now the machine working perfect.
          Thanks again
          God bless you all
