Ricoh C3503, C4503 Latest Firmware
  • Jinn
    • May 2023
    • 90
    Hi Experts,
    I am looking for the latest firmware of Ricoh C3503, C3003 and C4503.
    For C3503 the firmware installed is Version 1.36 and the Firmware P# D1475575Q,
    Which firmware version is the latest?
    If anyone can share the firmware files that will be a great help and much appreciated.
  • RandyW
    • Jan 2013
    • 213
    I didn't look up the latest firmware but some of the Ricohs now have firmware you can update over the network
    • Jinn
      • May 2023
      • 90
      Dear Ricoh Experts,
      If you do not want to share the firmware files then its okay. Fine. But at least share the version number of the latest number. I am looking for the version number also. So I can know my printers have the latest firmware installed.
      Please...!
        • 36745
        Considering that Ricoh discontinued that model 8 years ago, if it is not up to date on firmware, someone has been very remiss in servicing it. One other thing, the C4503 does not use the same firmware. Some modules are common across all models but not all of them. If you are seeing different versions listed between the C4503 and the C3503/C3003, that is why. In addition machines with the optional Smart Operation Panel (SOP) have firmware specifically for that, again some modules are common. The link that RandyW is your best bet. Select the Firmware tab and download the correct RFUT depending on whether you have the SOP or not.
        Product Codes for firmware
        C3503/C3003 no SOP C4503 no SOP C3503 SOP C4503 SOP
        D147 D146 D149 D148
