savin 8025e touchscreen adjustment
  • danceswrabbit
    • Dec 2013
    • 65
    Sharp tech here. have a friend with an old savin 8025e that the touch screen is off. In a sharp i'd go into test command 65 and adjust the touch screen. is there anything like that on this box? how does one access service modes and what test command is it? thank you for any help.
  • sandmanmac
    • 3981
    Damn!. There's a trip down memory lane!
    yes, there is a mode you can enter to calibrate the screen.
    I only have my aging brain to go by, but i "think" this is it: Reset 1 9 9 9 3 Clear/Stop (hold)
    If that doesn't work, It may be a 5 at the end (or possibly only two 9's)
    That's definitely "close" if it's not the correct sequence.
    Hopefully it gets you in.
      • 37487
      If I remember correctly it is Reset 1 9 9 3 hold Clear/Stop. Also it could be a touch screen that has gone bad.
      • sandmanmac
        • 3981
        I think your right about the number sequence, Tim, but as I think further, it now seems to me that was 3 x clear/stops at the end and hold the last one.
        My guess from the description is it's likely just a calibration issue
        • ccchuah
          • Mar 2009
          • 157
          Reset 1 9 9 3 and 5 times Clear/Stop key
          • danceswrabbit
            • Dec 2013
            • 65
            thanks guys will give it a try later this week!
