firmware upgrade via sp menu - f.i. imc2000
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    E71 error when we select firmware upgrade via sp mode on a
    imc2000
    and at a total different location als with a
    mpc3003
    Could it be that the firewall is blocking his path, because when we use the Ricoh Firmware Update Tool to update, it works fine.
  • j2shortt
    Learning to speak PCL...
    • Feb 2019
    • 56
    Re: firmware upgrade via sp menu - f.i. imc2000
    Originally posted by Mark Bbb
    Hoi,
    imc2000
    mpc3003
    I would imagine the routing this machine goes through to contact the servers is different than your update tool. I would just download the firmware to a memory card and restart the machine with the card inserted.
    pages 5-17 of the SM shows the error code with explanations.
