Ricoh Aficio Mp 2852SP Firmware Problem
  • Tommaso Fontana
    • Nov 2024
    • 12
    #16
    Help Me...
      • 36833
      #17
      Originally posted by Tommaso Fontana
      I did everything to the letter, now something has changed and I get "Download Error E44". Thank you
      More than likely you got a corrupted file when you downloaded the firmware of when you transferred them to the SD card. Otherwise you need to call Ricoh-EU and get a trained regional tech out there with a recovery SD card.
      • ccchuah
        • Mar 2009
        • 152
        #18
        Try copy the firmware to the SD card (prefered 1G card) which download from RFUT and try again
        Go inside the RFUT folder, you will see the temp folder, inside it got firmware folder, the download fw is inside it.
        Hope it may help....
        • Tommaso Fontana
          • Nov 2024
          • 12
          #19
          I did everything again but still the same error.
            • 36833
            #20
            Then call Ricoh support. You need someone onsite who knows what he/she is doing.
            • Tommaso Fontana
              • Nov 2024
              • 12
              #21
              Thanks to everyone I finally managed to update almost all the firmware myself. Now the only problem is this one as in the photo which doesn't let me update the fax firmware. Because the update starts but never ends. Other solution?
