Ricoh Pro c7200SX error sc590-03
  • gilbert
    • Oct 2017
    • 38
    [Error Code] Ricoh Pro c7200SX error sc590-03
    Morning Techs
    I have Ricoh pro c7200sx which is giving SC690-03.
    The error is coming when the device running a job.
    Ricoh service manual is pointing at ''communication between CRB left and IOB error''
    I have tested both the CRB left and right to a working device and error is not coming. I'm yet to test
    a IOB and harness between CRB and IOB.
    Anyone who has an ideal to this issue please assist.
    regards
    Last edited by gilbert; 10-05-2021, 08:04 AM. Reason: subject pro c7200 error sc690-03
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh Pro c7200SX error sc590-03
    I had it a few weeks ago and had to replace the TIM/MAG unit to sort it.
    Hit it.
    • gilbert
      • Oct 2017
      • 38
      Thank you very much for your response, Did you have SC690-03 and how about the CRB which is mentioned
      in the service manual?
      • gilbert
        • Oct 2017
        • 38
        Did you replaced TIM/MAG or the REVOLVER unit or both
        • TonerMunkeh
          Professional Moron
          • 3865
          Just the TIM/MAG unit and I had exactly the same code.
          Hit it.
          • gilbert
            • Oct 2017
            • 38
            Thank you TonerMunkeh for you contribution .I will test TIM/MAG unit to a working
            device and give you the feedback.
            • gilbert
              • Oct 2017
              • 38
              Morning
              I tested a TIM/MAG unit to a working machine, the error didn't
              appear even after running a lot of jobs.
              What could be the issue?
              • TonerMunkeh
                Professional Moron
                • 3865
                Interesting, I'd try and look at the replacement and adjustment settings in the service manual to see if the unit had drifted out of alignment for some reason.
                Hit it.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Also, did you try and use the unit in the other machine in the one you're having the problem with?
                  Hit it.
                  • gilbert
                    • Oct 2017
                    • 38
                    No i didnt try that . I'm now testing the while tray unit where the TIM/MAG are located
                    and its working fine. Could it be the IOB?
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      It could be, it could also be the harness from the left drawer to the IOB too.
                      Hit it.
