ricoh site not secure.
  • aviso66
    • Dec 2012
    • 202
    Ricoh logged in through web image says site not secure, can i make it a secure?
    • 37491
    There is a setting that will make WIM accessible only as https:// When set you will get "Access Denied" if you try to access it without https:// It has been years since I have had to correct someone accidentally setting it.
    • StephenB
      • Aug 2015
      • 243
      If you get a "security risk" prompt when logging on, use SP5870-003 execute then reboot the Ricoh
