Ricoh C7100 Not printing any Yellow
  • Heber302
    • Oct 2021
    • 16
    Hello Everyone!
    Thanks in advance for any help! I'm very new here so forgive me if I miss on providing any information. I have a Ricoh C7100 SX that will not print any yellow. All other colors print fine but absolutely no yellow. I replaced the yellow toner even though the other cartridge was not empty and I cleaned the unit as well. However after every print that I do I see that the Toner supply port on the development unit is packed with pure yellow toner. I am confused on what step to take next. Any ideas would be mighty helpful.
    Thank you!
    • 37529
    Re: Ricoh C7100 Not printing any Yellow
    I would say replace the yellow development unit. There is something internal that is broken.
    • TonerMunkeh
      Professional Moron
      • 3865
      Indeed. Take the drum, charger and cleaning unit out of the Y PCU and look at the mag roller. Does it have any dev on it? Do the paddle and mag roller gears turn freely?
      Hit it.
      • Heber302
        • Oct 2021
        • 16
        Hey guys thank you so much for the comments. After messing with the printer for a while, I realized the yellow toner was getting compacted in the toner whole that goes to where the developer is stored. I figured the developer motor was probably not working as it seemed the springs inside were not properly distributing the toner and developer. I took out the development unit and checked the gear inside the machine that is responsible to turn the developer springs inside the development unit. The gear was extremely loose.
        Next I opened the back doors worked my way until I got to the developer motor. I saw the belt that turns the developer unit was out of place. I put the belt back in its place and close the back doors and turned on the machine. The development unit started working as expected after the fix. I'm not sure how the belt got out of place but is been working fine since I fixed it.
        Thank you again for your help.
        • oconeeprinting
          • Jul 2023
          • 5
          I have a similar issue happening and thought I'd reply to this rather than starting a new thread. My issue is coming from black. The print out is significantly faded (probably 70%) and I will get SC348-11 to flare up shortly into any run. In the service manual, this calls for a toner supply issue and for the sub hopper to be replaced.
          I have a extra parts machine here and pulled the sub hopper off it and changed it out. No luck. I tried vacuuming the supply line as well. When I go through the processes for DEMS and any others, they all fail on black. I just put a new toner bottle in just before this happened and wondering if there was a clog in the supply line further up than I reached with the vacuum.
          Does anyone have any suggestions on how to test/remedy this? The machine is in the middle of a large book run right now and desperate to get back online.
          • oconeeprinting
            • Jul 2023
            • 5
            One other note to my post: we also swapped out the developer unit from our parts machine and that did not produce any changes either.
              • 37529
              This is a 3 year old post. It was dead and buried until you went grave robbing. Start a new thread or risk being ignored.
              • oconeeprinting
                • Jul 2023
                • 5
                https://www.copytechnet.com/forum/te...-ricoh-c7100sx
                  • 37529
                  Get lost Grave Robber
