MPC307. Wifi scan
  • GeorgeBest
    • Jul 2009
    • 526
    MPC307. Wifi scan
    Hi,
    Issue when connecting this machine on the Wifi,
    can someone explain?
    When installing this machine on the wifi instead of LAN I have no problems with printing.
    However, I can not make connection using the web interface, also scanning with the right configuration as if in LAN mode it is not possible.
    Are there more adjustments to configure using the scan mode on wifi?
    working with smtp.office365.com
    thanks in advance
    gr George
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MPC307. Wifi scan
    The wifi on the panel or the GW wifi interface?
    Hit it.
    • GeorgeBest
      • Jul 2009
      • 526
      Configured the wifi through the panel . .
      • TonerMunkeh
        Professional Moron
        • 3865
        Ah. Unfortunately the panel wifi only supports printing.
        Hit it.
        • mikadonovan
          • May 2008
          • 2931
          MPC306 printing & scanning WIFI
          NEVER ASSUME ANYTHING
          • gkalchik
            • Jul 2017
            • 19
            As far as scanning goes there is on more thing to consider. I just found out yesterday that Microsoft updates are disabling TLS 2.0 which is disrupting scanning, especially with Office 365. I normally work on Kyocera products and the following settings is what I was told to be out to be a work around:
            Serverside settings:
            Make sure TLS 1.2 and SHA2 are enabled.
            Clientside settings: TLS 1.2 enabled.
            Hash settings: Make sure all SHA2 settings are enable.
            You might want to make sure all other security settings are enabled.
            Now, this is for Kyocera products, hopefully this can apply to Ricoh, also.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Originally posted by mikadonovan
              Yep...some idiots never learn
              • Mark Bbb
                • Jun 2012
                • 1662
                yep, i remembered that too.
                • GeorgeBest
                  • Jul 2009
                  • 526
                  you're damm right . . .
