Ricoh printer driver
  • sasopine
    • Apr 2021
    • 13
    Does anyone know where I can find a printer driver for Windows 7 (32/64 bit) and Windows Server 2003/2008 for the Ricoh IM 370 and Ricoh IM 3000/5000 A?
    I am facing a big problem with customers requesting to be delivered a new generation of devices, but they are using old operating systems (windows 7).
    And on the Ricoh Japan website, drivers for windows 7 can no longer be found.
    Is there any solution to this problem?
    Thanks.
    • 37513
    Windows 10 driver should work.
    • sandmanmac
      • 3981
      Agreed. They will work
      • Saturn
        • Nov 2023
        • 171
        It is always a good idea to keep old driver CDs/DVDs. Current Ricoh machines will still run under Windows 2000 or Windows 98 if you install the drivers from the 25 year old predecessor models.
        .............and if you are lucky you can also find a computer with a DVD drive 😎
        I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
        • jumpinj18
          • Oct 2023
          • 9
          windows 10 universal driver will work had same problem with customer.
