Ricoh imc300
  • tekkie
    • Mar 2011
    • 114
    [Jamming] Ricoh imc300
    I have had an issue with a new imc 300 DF that has high usage on scan.
    It comes up with a JOO1 code which on this machine is the DF reg sensor
    There are only 2 sensors on this DF 1 paper set sensor and 1 reg optical sensor.
    It can work perfectly well for 2 or 3 weeks then the reg optical sensor detects a jam and it wont clear at all even if I switch off completely it stil wont reset.
    If I take out the reg sensor carefully whilst switched on and brush the area where it shines through it clears.
    We have replaced the mc once and its had 3 new DFs complete and its the same fault on all 3 DFs and both mcs.
    I am suspecting there may be an issue with false jams on this model with high usage scans.
    Its a very clean environment and very good originals when I look in the DF there is no paper dust has anyone had this issue on imc 300 or imc 400.
    Its got the latest firmware on mc and DF and as I stress its the same on 2 mcs and 3 DFs
    This has been passed on to Ricoh who are investigating pls let me know if anyone has any ideas or has had the same problem
  • 8T2
    • Aug 2015
    • 257
    Re: Ricoh imc300
    If it's the same ADF as on the IM350 there's a big chance that the sensor actuator unclipped on the one side, ran into it the other day and thought it's a really stupid flimsy design
    Sent from my WAS-LX1 using Tapatalk
      • 37558
      Re: Ricoh imc300
      Common problem on doc feeders with a high scan usage, especially if the originals are older documents that are being brought out of physical storage and being scanned into electronic storage. Dust that has accumulated in the paper falls down on the sensors to the point where the sensor cannot recognize the trail edge of the paper. After the customer checks for the original jam and closes the cover it still see the dust and thinks there is an uncleared jam. If you check the jam history you will most not find any J001 jams listed. Instead you will find the number of the actual jam.
      Usually it is a sensor that uses a black felt pad as a black reference for a reflective sensor.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Re: Ricoh imc300
        If there's a black reference pad I sometimes color it in with a Black Sharpie as sometimes blowing it or dusting it isn't enough.
        • Mark Bbb
          • Jun 2012
          • 1662
          Re: Ricoh imc300
          I have had = problem on 2 mpc3002's at the same location, in the same room!
          Static electricity was the issue, because the (beautiful) carpet loaded up the MFP user in such way that the static electricity uses the metal on the mfp to discharge, so disturbing the DF sensors!
          It helped when we put a large plastic plate on there carpet.
            • 37558
            Re: Ricoh imc300
            Static can be a huge problem and troublesome to get rid of.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Re: Ricoh imc300
              Especially in hospitals with nurses wearing Nylon stockings...!!!!
