jam recovery in ricoh 1107ex
  • antoney suresh das
    • May 2011
    • 103
    [Error Code] jam recovery in ricoh 1107ex
    Hi Guys,
    I have a problem with one Ricoh 1107 the machine is working perfectly but when a paper jam occurs it takes time to recover where as the other machine of the same model recovers almost instantaneously can some one guide me as to what could be the reason is it something to do with the settings?
    thanks
    • 37488
    Print SP5-990-006, non-default for both machines and compare. Most likely one or more of the fusing settings are different and causing a longer time to warm back up.
    Also are all downstream peripherals the same? They have to all re-initialize before the main frame restarts.
      • May 2011
      • 103
      Thanks Slimslob for the guidance i will make a comparative analysis i know you're the only one who would post . One cannot doubt the depth of your knowledge in our field.
      Wish you A Merry Christmas and A Great Year in 2025.
      Wishing all the Guys on our platform a Merry Christmas .
