Urgent Attention Required for IM C2010 Printer Issue.
    • 37489
    #31
    Originally posted by nadimtopsecret
    I would agree with you if it were a single printer or 2-3 printers at the same location. However, this issue is occurring across 20-23 different customer locations. Additionally, even after disconnecting the LAN, the machine is unable to print anything, even after performing a memory clear and HDD format.
    And in the early days of the MP CXX03 occurred worldwide.
    • nadimtopsecret
      Experienced Tech
      • Mar 2013
      • 47
      #32
      Yes, that's correct. However, I’ve also gathered information from India and they haven’t faced any similar cases so far in the IM C2010. Additionally, in our country, over 60+ devices of the same model have been installed, but only 20-25 of them are affected.
      • nadimtopsecret
        Experienced Tech
        • Mar 2013
        • 47
        #33
        Update -
        Tried with replacing a BICU, but not resolve
        • Gift
          • Mar 2011
          • 2459
          #34
          That's hard to believe that this affects so many devices at the same time. Did they all received a firmwareupdate beforehand? Did you try and reset the machine with the data clear feature in admin tools (aka not SP mode)?
          Usually in these cases issues are gone if you hook up your laptop with a direct lan connection and to a test print.
          • mfrigault
            • Feb 2017
            • 18
            #35
            It happened to me on a IMC2500 - could not print counter page, could not copy, could not print, but scan to email worked. Customer was using aftermarket toner. We ended up executing Engine clear SP5801-2 and all started to work again. It would surprise me that all of these printers stopped working overnight because of that.
            • Codex
              • May 2008
              • 704
              #36
              Maybe some windows update??, you said that the problem appears "overnight".
              Memento Audere Semper
              • copyboy99
                • Jan 2020
                • 24
                #37
                Does these devices on PoE ethernet port/switch/router?
