im 350f Legacy ui error.
  • LeeTC
    • Dec 2024
    • 8
    #16
    Originally posted by sandmanmac
    Why not post your solution for all of us?
    That's kind of the whole point of this site.
    I wont mention the access code that is needed as i see others are wary of doing the same on here.
    Basically you need the legacy ui file for EDC, i needed to access a service menu which lets you install the legacy ui which then lets the machine communicate properly with the display.
    Then latest firmware got us up and running.
    The code is similar to the one beginning with an 8
    If people are ok with the access codes being public knowledge i will post it on here. Personally i am not but hey ho
    • LeeTC
      • Dec 2024
      • 8
      #17
      Originally posted by luca72
      here it is, I got the correct procedure wrong [reset]+1+4+3+[C] (2 times and the last one hold down, otherwise the sp does not appear)
      Appreciate your help pal, but machines would not go into service mode at all. I am aware of this setting and was one of the things i wanted to check first but could not get access.
      Tried 3 codes to access service menu and none worked, the code i used is similar to 80 one.
        • 37513
        #18
        Have you tried powering ON with all the doors open? This should prevent the Engine from starting. This will prevent a Service Error Code from blocking SP access. The only other thing I can think of that would prevent you from accessing SP would be Service access being blocked in Administrator settings.
