Customer called for noise which I found to come from the fuser unit. I had just replace the upper fuser roller and both gears fuser drive as well as heat roller gear. I separated the two rollers and they both moved freely. I cleaned the heat roller bushings and reassembled rollers turned freely. Also the upper roller had a red tint to it which is not coming from the lower roller or from what customer is copying any thoughts on the tint problem and possible causes for unit seasing up?
Thanks!
Thanks!
