what is the upgrade model for MP C2800 !
  • Maged_elagamy
    • Mar 2021
    • 42
    a customre had 2 RICOH MP C2800 and everything is going well
    he needs to replace the older copier with new RICOH model such 3003 or 3502 , etc...
    which model will give him the same quality and stabilty as MP C2800 ?
    PS : he uses compatible toner not OEM
    thanks
    • 37532
    Re: what is the upgrade model for MP C2800 !
    Neither the C3003 nor the C3502 are "new" copiers. As for color quality in that speed range, go with the 02.
    • Maged_elagamy
      • Mar 2021
      • 42
      i think the fuser unit in mp c3502 is weak compared to mp c2800
      what do u think !
        • 37532
        what do u think !
        Not as weak as the fusing sleeve on the 03s. If you want something with an actual hot roller you have to stick to the 00s and 01s.
