2232c making grinding noise
  • ash_572
    • Oct 2008
    • 523
    i have come across afew of these problems now. the gears on the transfer cleaning unit struggle to turn. so i took the transfer cleaning unit out and it was perfectly fine unitl i put the cleaning unit back in. most of the times i jus swap the tranfer unit with a another and its fine. wat is exactly causing this problem??
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Crappy machines all around. You probably won't find anyone with a nice thing to say about these. Wouldn't it be nice if you didn't have to buy the whole pcu when the cleaners crapped out? I don't have a reason, other than toner build up inside the units. Since you have to replace the whole unit when this happens I haven't ever bothered to take them apart to find out why.
    • rthonpm
      • Aug 2007
      • 2847
      I actually will say something nice about these machines. I used to have close to sixty of them in my area and they never gave me much trouble at all. I had more issues with fifteen LD035's than I ever had with all of my LD232c's.
      It almost sounds like the transfer unit isn't seated correctly or it's just sort of slipping along the belt. If swapping them out doesn't move the problem, does the donor machine have fewer clicks on it? If so, it could be a newer blade now on an older transfer belt or vice cersa after the swap.
      Also, is the machine giving you noise level? Sometimes if put on an uneven surface these boxes would do odd things and make strange sounds...
      • cobiray
        • Mar 2008
        • 1199
        The exception that proves the rule...
