Equitrac - uninstall on a sop (cheetah) display
  • Mark Bbb
    • Jun 2012
    • 1662
    There is no way to access the sp mode.
    We do not have any (admin) card to log in the Equitrac software.
    We have bought this machine from Ricoh itself.
    Someone, please?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Equitrac - uninstall on a sop (cheetah) display
    If it's PCC5, you can hit the hamburger menu at the top right, go into Administration then get into SP mode from there.
    Hit it.
    • Mark Bbb
      • Jun 2012
      • 1662
      Dear c.t., there is no hamburger menu, even "login" is not highlighted (but it is on the screen).
      This is the PCC 4 version
      • TonerMunkeh
        Professional Moron
        • 3865
        What sort of machine has it been installed on? PCC4 doesn't install to the SOP. It's installed into the Java on the controller if it's an '04 or IMC.
        Hit it.
        • Mark Bbb
          • Jun 2012
          • 1662
          IMC4504
          • CopyBats
            • Aug 2011
            • 147
            Someone, please?
            Did you try using the hidden buttons on the left side of the screen. Hidden with a small cover within the SOP.
            If it works, don't touch it.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Try this:
              PCC4bypass codes.
              User name: 01231230
              PW:2468
              • Mark Bbb
                • Jun 2012
                • 1662
                Originally posted by Oze
                Try this:
                PCC4bypass codes.
                User name: 01231230
                PW:2468
                Oze, thanks, but this machine is no more in its network, we have bought this from Ricoh itself.
                I have tried the code you have suggested here, but nothing changes.
                Yesterday i had a technician from Ricoh on the phone and he told me to first press a red button (which one, there are 3 red buttons???), than the green one and then the code you have given here. But... no good.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  C.B., good thought, i have located them.
                  And now?
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    And now?
                    Try pushing in the bottom button and touch the "check Status" part of the screen at the same time.
                    That will pull up a numeric keypad.
                    Usually with PCC you need a user to login before this will get you into service mode but it won't hurt to go ahead and try.
                      • 37532
                      Someone, please?
                      I know that on the early models with SOP you could add the Classic Copy Function to te desktop and use it to get into SP mode.
                      • davel
                        • Oct 2011
                        • 1107
                        Someone, please?
                        Ask your Ricoh rep how to fix it or send it back to them.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          that is what we did, and it is solved now.
                          Thank you for helping us!
                          • blurry89
                            • Feb 2024
                            • 1
                            could you help i am in the same situation. i bought printer from a school and now can't use it.
                              • 37532
                              When you start a new thread. This one is over two years old, was dead and buried.
