AF 2022/2027 Scanner Option
  • dv007833
    • Aug 2008
    • 43
    Hi,
    Is there anyway to disable the scanner feature on this model?
    From what I am aware the DIMM card has a 2 in 1 feature (Printer/Scanner). Or are there models that come with the printer DIMM by itself?
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 365
    Remove the scanner button on the op panel and put a blank button on it and then it can not be accessed from the panel.
    Or the other option is to enable user access codes for the scanner and don't give anyone access to the scanner.
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
