Ricoh c4503 and Ricoh finisher 3210
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Can the Ricoh Finisher 3210 be used on the 3 series copiers? On my Konica machines the new finishers for the 8 series can be used on the older 4 series and the Ricoh C4504 finishers sure look like the 3140 finishers for the C4503. Just wondering if anybody has tried installing one of those 3210's on the 3 series copiers. Thanks in advance.
    • 37532
    Re: Ricoh c4503 and Ricoh finisher 3210
    Most likely not. Probably different firmware and electronics.
    • mikadonovan
      • May 2008
      • 2931
      PSG lists SR3130, 3140, 3150, 3160, 3170, and 3180 to be compatible with this machine.
      NEVER ASSUME ANYTHING
      • fshead
        • 2376
        I never took a chance trying old sorters on newer machines.
        It is not worth killing a controller unit or others boards to find out.
        There are plenty of excess sorters out there,check with the lease resellers.
