Deployed V4 driver Locked printissue
  • rthonpm
    • Aug 2007
    • 2854
    #16
    Re: Deployed V4 driver Locked printissue
    Originally posted by tinalt
    I feel like you are seeing some option that was presented that I am not. I can,
    1. Deploy drivers to the workstations using admin credentials(which the customer does not want)
    2. Do nothing and leave it broken
    3. Move them to a manufacture that has figured out how to use V4 drivers
    What are you seeing as an option that I am not?
    If the customer's IT also can't figure out how to script a deployment of the V4 driver to the machines they manage, then they need to seriously consider finding a new line of work.
    As for the admin rights needed for adding a printer, that's only needed the first time a user connects to the spooler of the print server. That can also easily be done by IT, either by 'seeding' machines by connecting to the server from their admin account or actually configuring the GPO's required to trust the print server in their facilities.
    This isn't a machine issue, it's a lazy sys admin issue.
    Sent from my BlackBerry using Tapatalk
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      #17
      As per my last post that requires admin rights to install on the clients, hence a non option per the customer
        • 37491
        #18
        So does installing a new printer if you sell them a Canon. Now stop lying.
