Question about a Lanier 5635
  • longhaul
    • Jun 2025
    I resently acquired a used lanier 5635with a duplex unit installed. When I recieved it it had an error code, which I later found out was a hard drive error. I disconnected the hard drive, the unit works just fine now. My question is what do I need to do replace that drive, its a Maxtor 20gb, i.e. anything special or do I just format it FAT32 and slap it in.
    Also would like any info about this unit. I am presently useing it as a personnal printer/copier/scanner, but would like to install the fax option, if I can find one. Also where can I find parts for it, the document feeder needs the rollers replaced, because it will not feed any pages. Thanks for any help you guys can give me.
    P.S. I am familiar with working with HP printers, this is my first MFP.
  • Jimbo1
    • Mar 2008
    • 845
    Slap it in and format it in the machine.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • longhaul
      Thanks, any idea where I can find a service manual for this unit?
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Try here for manuals. He supports the site and is an active member.
        http://www.manuals4you.com
        For rubber rollers try Katun or google for others.
        • longhaul
          Thanks, I will check it out. I'm new to copiers and to Lanier, how hard are they to work on. I have worked on mostly HP printers. Thanks again for the link.
          • cobiray
            • Mar 2008
            • 1199
            It's just a re badged Ricoh. IMO they are easy to work on. If you are mechanically inclined and understand the basic copy process, you will be fine.
            • longhaul
              Thanks guys for all the info. This unit was never really cared for anyway.
