mp6001 and mp6002 need postscript to print on linux?
  • medallo
    • Dec 2008
    • 21
    Hi guys. mp6001 and mp6002 need postscript to print on linux? I'm lost Thank you
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: mp6001 and mp6002 need postscript to print on linux?
    The short answer is "yes".
    The long answer is "it depends". Some versions of Linux (with the right configutaion) can print PCL, but it's not easy to set up.
    Just use PostScript and you life will be much easier.
    • TonerMunkeh
      Professional Moron
      • 3865
      Part numbers:
      MP6001 - D4625020
      MP6002 - D6205020
      Hit it.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Originally posted by TonerMunkeh
        Part numbers:
        MP6001 - D4625020
        MP6002 - D6205020
        Always try to buy these new, or at least with a guarantee.
        If improperly removed from a machine, they are useless. When installed, the machine's ID gets written to the card, and is not removeable. A proper uninstall erases that data so that the card can be reused.
        • rthonpm
          • Aug 2007
          • 2854
          The native printing system in Linux is CUPS, just like on Macs. Most distributions will have a pre-loaded series of drivers for most models. Checking my Ubuntu VM, the PostScript drivers for both the 6001 and 6002 are there. For any distro that doesn't have the driver, you can always get it from the Open Printing site: Printers by Manufacturer | OpenPrinting - The Linux Foundation
          You can also integrate Linux systems into a Windows print server by using the name of the print server as the address for the printer and the share name as the queue. You'll need to then add the right Linux driver on the local machine. This won't work with any Windows queues using Type 4 drivers though.
          • tonerhead
            • Sep 2009
            • 582
            Linux systems have come a long way since the days of postscript only. Most linux distros will use pxl and have the drivers built into the system. For example I am running Lubuntu on an older computer and the drivers for pxl for these 2 machines are built into it. I am also using Peppermint Linux (debian) it is also built into it. I can't speak for Red Hat distros or distros other than debian. If your customer is using a debian distro, it should be easy to add these printers. You might not get full functionality, like watermarks, margin shifts, etc but you should get tray select, duplex, and maybe some finishing options. I would suggest trying it first before ordering postscript.
            I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
            Especially when it comes to sex
            • tonerhead
              • Sep 2009
              • 582
              You can also go to openprinting.org. Select the ppd download. Select Ricoh, PXL, mp6001 or mp6002. You can download and install ppd for linux. This should work if printer has no postscript.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Remember that the only supported method in Linux is to use PostScript.
                If features are missing, fonts and/or colors are goofy, printing is slow, etc...you're on your own. Been there, got the T-shirt.
                May be great to try in you own envionment, but not a customer's.
                • tonerhead
                  • Sep 2009
                  • 582
                  True, your mileage may vary. On a side note, I think it was the 03's in windows drivers The magenta color would not reproduce correctly when even hard coded in gimp or photoshop. When I contacted mother Ricoh about it. They said for exact color you need postscript not the pcl. We passed that info onto the customer who switched to another vendor before the lease was even up they didn't want to pay $$$ for the upgrade. It's too bad that the entire industry doesn't switch to a standard. Wouldn't that make life easier?
                  Explain to the customer your mileage may vary, but let's try it first. Afterall, the more clicks the more income generated. If they aren't satisfied, sell them a postscript chip. Those are older machines so they probably won't. Just explain what you are trying clearly.
                  • rthonpm
                    • Aug 2007
                    • 2854
                    I've had mixed success with the PXL drivers. I often see as many PCL error reports as completed prints. Some of it seems to depend on just what they're printing. Real documents and PDF seem to work well, websites and automatically generated reports seem to flake out.
                    Sent from my BlackBerry using Tapatalk
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      • tonerhead
                        • Sep 2009
                        • 582
                        Very good point, you will not find this for linux.
                          • 37490
                          What about Print to Document Server?
                          • rthonpm
                            • Aug 2007
                            • 2854
                            One workaround I found for this on a couple of models was to extract the PostScript driver for Windows using 7-Zip and to use the .ppd file included in it on Linux systems. I haven't had to do it in awhile since most of my customers have gone away from user codes and my customers with Linux boxes never used them at all.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              That only works when the machine has PostScript.
                              My example was for when it did not.
