MPCW2201SP SC202-32
  • mycfx
    • Aug 2014
    • 4
    MPCW2201SP SC202-32
    This 2201 gas been in the field for 2 years. Just about 60 days ago had to clean print heads and the flush print heads for light to no print on page.
    Has been working since.
    Yesterday went to service call for sc202-32 Head Tank 2 : purge Error.
    I have ordered print heads and am awaiting them.
    Wanted to get input to see if anyone else has had this issue and could comment with any details.
    Thank You,
    • 37433
    Re: MPCW2201SP SC202-32
    What are the PM counters and main count for this wide format? After 2 years it may be time to replace the maintenance unit. Head tank 2 is a function of the maintenance unit.
    • mycfx
      • Aug 2014
      • 4
      I am offsite from that call, but have the counts from the ticket.
      The counts are;
      Color Total 41378 SQFT
      Black Total 16530 SQFT
      Also had the "Ink collector unit is almost full" just come on. Customer has been repowering mpcw2201 off and on.
      Still down with sc202-32
      • Brianneoe
        • May 2015
        • 318
        Make sure you read "Before you Begin" in the SM for replacement of the Ink Supply Unit. If you don't have a service manual, get one. Watch out for ink spilling onto the encoder strip on the carriage unit. It's right behind the ink heads and the carriage runs along it. The ink heads clip into the carriage unit so don't worry if you have to use some force to get them out.
        Also take a lot of pictures on how the tubes are routed.
        SP 2102-4 will release the carriage from the Left Ink Stump. That's your start point if you don't have the manual.
        Good luck
        • mycfx
          • Aug 2014
          • 4
          Good luck
          I have the manual. Parts are in today. I'll take pics and follow the manual. Gotta love the complexity of this, Thank you Ricoh. Just did a HP wideformat rebuild in the shop, what a breeze.
          • mycfx
            • Aug 2014
            • 4
            So, I just installed the color print head, black print head, maintenance unit and collect bottle .
            Installed the maintenance unit first, code 202-32 remained.
            Installed the black and color print heads and now it is up and running.
            FYI, the print heads are kits. Have the print head, waste tank, ink to flush with, print head shield for when you are disconnecting ink lines, and plug off pins for ink lines and print heads.
            Manual details were good, just one issue was that I had to turn on machine with door open to use sp to uncap print heads. Would not work sp if code was present and machine fully booted.
              Did you install parts with the door open?
              Did you reset parts counters?
