Do Ricoh MP C3300 toners work in an MP C3001?
  • patterson70
    • May 2010
    • 599
    I see some cartons say both models but other cartons either have one model or the other.
    Not sure if they are interchangeable unless both models are listed on the carton.
    • 37488
    Only if you are buying compatible from a second or third rate seller.
    • patterson70
      • May 2010
      • 599
      I wanted to mention I have cartons that are genuine Ricoh that have both models on them.
      So one version of genuine does fit both.
      Not sure if the 3300s that don't say 3001 will work though.
        • 37488
        Mia culpa. I was thinking 3001 and 3000. I remember there was one model that came out back then where some toners were the same but not all. Can't remember if it was colors fit but not black or black fit but not all the colors.
        • patterson70
          • May 2010
          • 599
          No problem, thank you for this. Only one way to know, I will try to see if the 3300 will work in the 3001.
            • 37488
            If you can get the Product Support Guides it would be listed there.
            • sandmanmac
              • 3981
              Colour toners are the same for both series. Black is different
              • Lions86
                • May 2021
                • 5
                The chips of the BLACK toners of these two models are different. In other words, the BLACK toner will not work, but you can use the same COLOR toners.
                • patterson70
                  • May 2010
                  • 599
                  Thank you all for confirming this!
                  • fshead
                    • 2376
                    colors interchangeable but black is different..pop the head ad swap if needed
