Pro C7110X intermittently doesn't fuse,machine cycles long time/no sc codes
  • Craig2309
    • Jul 2017
    • 11
    I have a C7110X that intermittently will not fuse ,the machine will cycle saying its adjusting fuser temperature,then after say 3 minutes of this will start the print job and everything that comes out is smeared from not fusing,doesnt matter what media from plain paper to 100lb cover,swapped entire Fusing unit with a rebuilt unit same issue,updated firmware,same issue,replaced fusing roller pressure motor assembly,same issue,ideas??
    • 37474
    Re: Pro C7110X intermittently doesn't fuse,machine cycles long time/no sc codes
    Have you gone into SP mode and monitored fusing temperatures? Sounds like the temperature of something is fading quickly and slow to warm back up. Usually the pressure roller. Often because someone put a 220 volt lamp in a 120v machine.
    • butcher
      • 48
      Check the fuser connectors inside the device cavity . Just in case they're dirty / damaged or have paper stuck in them.
      • Gift
        • Mar 2011
        • 2459
        What does the enviroment sensor put out in terms of temperatur/humidity? What's your impression of that site?
        • satins
          • Feb 2021
          • 89
          Please do check the fusing inter connector at the back. The male is with the removable fuser and the female is hooked on the equipment facing forward.
          I have encountered one similar issue with the small piece of paper stuck and sitting on the inside of the female connector.
