ricoh 1035
  • tcypy1961
    • 773
    ricoh 1035
    I have posted about this copier before concerning sc 861 error code. I went out to the copier on friday and performed a reformat of harddrive. customer called back stating that all document server matierial was gone. can this be retrieved or will it have to be re-inputted? thanks!!
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    The one warning I give customers when I gave key op's on the document server feature was to treat it like a computer; WHEN it goes out someday, the documents are gone. Of course, I said it in a nice way, but I did want them to understand that because of the copier movement, heat, etc, that the HDD is subjected to more stress than a normal HDD in a computer, and they usually just accepted it.
    They'll just have to scan in those documents again and re-label them. Also, double check the key op setting for when the documents get erased and make sure that the setting is off of the default time to delete, which I think was three days.
    Unless someone else knows of a trick, I do not know of a way to retrieve these documents. Once you reformatted it, those are gone.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • Ricoh-ono
      • 339
      Once it's deleted from the HDD it's gone. Everything will need to be rescanned and stored.
      Do what you can, with what you have, where you are. ~Theodore Roosevelt
      • copygirl
        • 75
        Once it's reformatted it's gone. Sorry.
        Ginger
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          That's a bugger.
          A customer that actually uses the document server feature.
          • KopyKat
            Nurse Ratched of Repair
            • Nov 2008
            • 365
            So sorry this happened to you...been there done that! Format destroys the files.
            If the copier is connected to the network for printing and they have at least some of the documents in electronic format, they can print them to the document server by choosing "Job Type = Document Server" This allows them to do it quicker and name the file when sending to the Doc Server.
            If you are considering a format for any reason, always check the doc server and print out the documents before you format...if you can. Sometimes you get lucky and can save their docs and sometimes not.
            sigpic
            Relax! This firmware injection won't hurt...but it will take 45 minutes.
