M2700
  • babu
    • Apr 2018
    • 19
    M2700
    How can i print M2700 from Apple pc???, and how can download driver for Apple pc
  • 8T2
    • Aug 2015
    • 257
    Re: M2700
    If it has optional PS Unit installed install the PS driver, if no PS is installed the rubbish generic PCL6 driver. Both available from ricoh-support.com
    Sent from my SM-A305F using Tapatalk
      • 37628
      Re: M2700
      The PCL emulation should be available on the the Apple without installing anything. The Generic PCL Printer comes with all Apple OS. You just have to know where and how to find it. The only thing is that it knows absolutely nothing about options like paper trays, duplex and finishing. Newer Mac versions have no way of designating Color and B/W.
      HP printer setup (Mac PostScript and PCL drivers) | HP(R) Customer Support.
      • sandmanmac
        • 3990
        Re: M2700
        Had to do a quick google on that model.
        Printer languages are not my area of expertise at all, but brochure states it's GDI only.
        That seems to me that it might need a bit of "tweaking" on a Mac, although it does state that it supports mobile print with MAC Airprint.
        RICOH M2700.pdf
          • 37628
          Re: M2700
          [ATTACH]51904[/ATTACH]
          If it supports Airprint then that is the way to go. My understanding of GDI, Graphic Device Interface, is that the computer has to talk directly to the engine of the printer, no controller board, no IPU.
