1-click-settings: Englsih server versus German client?
  • Peter2
    • Jan 2022
    • 8
    I have Microsoft Server 2019 as Print Server and the Ricoh PCL 6 German, Version 4.32, as print driver and Win 10 German computers. All the menus in the "Ricoh printer configuration" - and of course the 1-click-settings - are in German. The problem is: When I define a 1-click-setting on the server and it is selected on a PC, then I get this message. It happens also in the other way - I define a 1-click-setting on a PC, export a json-file, import it on the server and select it on the user.
    Simple translation:
    This [1-Click-Setting] can not be used by this model or for the current settings of options.
    The following settings were not reused / reproduced:
    - Bitmap
    - Overlay-Data
    - Watermark
    The special effect is: I don't neither Bitmap nor Overlay nor Watermark ...
    What's the background of this behaviour?
  • Codex
    • May 2008
    • 701
    Re: 1-click-settings: Englsih server versus German client?
    [ATTACH=CONFIG]51931[/ATTACH]
    Simple translation:
    Hast du es schon mit dem PCL Universal Driver probiert?
    (did you try the universal Print driver?)
    Memento Audere Semper
    • Peter2
      • Jan 2022
      • 8
      (let's stay in English ..)
      Yes, it is the Universal Print Driver.
      Why are you asking? In other postings Ricoh PCL 6 Universal: Export, saving and import of settings? it was advised not to use it.
      • Peter2
        • Jan 2022
        • 8
        I think I found the problem (but not the most effective solution):
        The Server-version messes up English and German - e.g. it uses the string "Confidential" as system-setting for a (non-used!) watermark. And the PC-version uses only German strings and does not understand the settings. And because that's all "standard-system-settings" it can not be modified. Maybe I will define a setting "xyz" which can be understand ....
        Edit:
        "Maybe I will define a setting "xyz" which can be understand ...."
        Not that easy - "Bitmap" needs a defined, existing Bitmap, "Overlay" needs a defined OPP-file (??).
        Mad...
