I just installed a Ricoh MP C4504ex scan problems
  • Bossman
    • Jan 2020
    • 4
    I turned off admin log in. Set up print but doesn't see the scan destination. Says it cant be used Now. Is there a setting that i am overlooking?
  • sandmanmac
    • 3983
    I dunno.......You've given about 10 words about what you've done, and my crystal ball is in for service.
    First thing to me seems like you should have tested the features prior to installation.
    Could you be ANY more vague?
    • Mako
      • Jan 2025
      • 906
      There is nothing in the original post I can use to guide you.. You scanning to folder, email URL?
        • 37553
        What do you mean by turned off admin log in? Are you referring to administrator authentication? If so you have made the machine vulnerable to having settings changed by anyone standing in front of it, like a competitor.
        You're not trying to scan as admin are you? Admin does not have rights to use functions such as scan and fax.
        • Bossman
          • Jan 2020
          • 4
          I fixed i had to turn off a security feature .
