ricoh FT6645 sc302 error
  • raym
    • Apr 2005
    • 62
    i\'m a mita/cs tech and have a friend that has a ricoh ft6645 with a sc302 code. can someone guide me in the right direction as i have no manuals on this beast. it\'s the only one i\' ve ever worked on and i\'m basically lost. can someone give me the corrective action and if i have to reset code, how do i do that? any help would be appreciated as i am quite the novice on this machine.
    thanks much,
    ray
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re:ricoh FT6645 sc302 error
    hmy: This code is typically a charge corona problem. Either a charge leak or a problem with the charge wire cleaner. Power off/on should reset after the cause is corrected. :evil:
    Mystic Crystal Revelations
    • spiky
      this code reset upon turning of and on. the problem is the charge corona. check the contacts, springs and wires. If all are of leave the charge in the dr unit open the top cover(1 screw) you will see a contact touching the casing of tne charge unit remove it and clean it. Toner build on this causes poor grounding.
